[Bio] / FigCommon / switch_to_release.pl Repository:
View of /FigCommon/switch_to_release.pl
Revision 1.6 - (download) (as text) (annotate)
Fri Dec 19 20:59:20 2003 UTC (16 years, 2 months ago) by efrank
fix rt thingie
use FIG;
# switch_to_release <release_number>
# Change the currently-running release to <release_number>
# Check to be sure that $fig_disk/dist/releases/<release_number> exists
# Update $fig_disk/CURRENT_RELEASE with the new release number.
# Swing the symlinks $fig_disk/FIG/bin and $fig_disk/FIG/CGI to the right place
if (@ARGV != 1)
    die "Usage: switch_to_release release-number";
my $release_number = $ARGV[0];
my $release_dir = "$FIG_Config::fig_disk/dist/releases/$release_number";
# FIXME
my $arch = $ENV{RTARCH};
if (! -d $release_dir)
    die "Release directory $release_dir does not exist"
# Okay, go for it.
if (!open(FH, ">$FIG_Config::fig_disk/CURRENT_RELEASE"))
    die "Cannot write to $FIG_Config::fig_disk/CURRENT_RELEASE";
print FH "$release_number\n";
close(FH);
# Symlinks.
unlink("$FIG_Config::fig_disk/FIG/bin");
symlink("../dist/releases/$release_number/bin/$arch", "$FIG_Config::fig_disk/FIG/bin");
unlink("$FIG_Config::fig_disk/FIG/CGI");
symlink("../dist/releases/$release_number/CGI", "$FIG_Config::fig_disk/FIG/CGI");
&FIG::run("cd $release_dir; make clean; make");
# Fix up permissions so we can do things as a different user later.
chmod(0777, $FIG_Config::fig_disk);
chmod(0777, "$FIG_Config::fig_disk/FIG");
chmod(0777, "$FIG_Config::fig_disk/FIG/bin");
chmod(0777, "$FIG_Config::fig_disk/FIG/CGI");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk/CURRENT_RELEASE");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk/FIG");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk/FIG/bin");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk/FIG/CGI");
&FIG::run("chmod ugo+w $FIG_Config::fig_disk/dist/releases");
&FIG::run("chmod  -R ugo+w $release_dir");
