[Bio] / FigCommon / switch_to_release.pl Repository:
View of /FigCommon/switch_to_release.pl
Revision 1.11 - (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 6 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, help, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.10: +17 -0 lines
Added license words.
# Public License.
use FIG;
# switch_to_release <release_number>
# Change the currently-running release to <release_number>
# Check to be sure that $fig_disk/dist/releases/<release_number> exists
# Update $fig_disk/CURRENT_RELEASE with the new release number.
# Swing the symlinks $fig_disk/FIG/bin and $fig_disk/FIG/CGI to the right place
# Create the symlink $fig_disk/dist/releases/current to point to <release_number>
# Create a symlink $fig_disk/dist/releases/last to point to the pre-switch release.
# Expand the environment-specific tool headers from $fig_disk/config/base_tool_hdr
# to include the release-specific directories. Place the output in
# dist/releases/<release_number>/<arch>.
require FigCommon::SwitchRelease;
if (@ARGV != 1)
    die "Usage: switch_to_release release-number";
my $release_number = $ARGV[0];
# We assume the architecture name is keept in $RTARCH in the environment.
my $arch = $ENV{RTARCH};
FigCommon::SwitchRelease::switch_to_release($FIG_Config::fig_disk, $arch, $release_number);
exit 0;
