[Bio] / FigCommon / setup-sge.pl Repository:
View of /FigCommon/setup-sge.pl
Mon Nov 1 20:21:37 2004 UTC (15 years, 8 months ago) by olson
CVS Tags: merge-trunktag-bobdev_news-2, Root-bobdev_news, merge-bobdev_news-1, merge-trunktag-bobdev_news-1, merge-bodev_news-3, lwc, caBIG-00-00-00, merge-bobdev_news-2, merge-trunktag-bodev_news-3
SGE setup stuff.
# Configure the SGE install for this machine.
# We copy the SGE directory from the common runtime
# directory to the directory FIGdisk/gendb/SGE so that
# we can have a custom installation as part of the build
# (this should help in the configuration of the system
# if one copies a figdisk from one machine to another).
use FIG_Config;
use FIG;
my $root = "$FIG_Config::fig_disk/gendb/SGE";
my $cell = "default";
if (-d "$root/$cell")
    die "It appears that SGE is already configured in $root.\n";
my $sge_src = "$FIG_Config::common_runtime/sge";
if (! -d $sge_src)
    die "Cannot find SGE source directory $sge_src\n";
&FIG::verify_dir($root);
my $rc = system("cd $sge_src; tar cf - . | (cd $root; tar xfp -)");
if ($rc != 0)
    die "Copy of sge from $FIG_Config::common_runtime/sge failed\n";
# Just use these defaults for now.
my %replacements = (ROOT => $root,
		    QMASTER_PORT => 10111,
		    EXECD_PORT => 10112,
		    CELL_NAME => $cell,
		    GID_RANGE=> '20000-20100',
		    ADMIN_HOSTS => "localhost",
		    SUBMIT_HOSTS => "localhost",
		    EXEC_HOSTS => "localhost",
my $conf = "$root/SGE_Config";
open(CONF, ">$conf") or die "Cannot open $conf for writing: $!\n";
while (<DATA>)
    my $k, $v;
    while (($k, $v) = each(%replacements))
	s/\@$k\@/$v/g;
    print CONF $_;
close(DATA);
close(CONF);
chdir($root) or die "Cannot chdir $root: $!\n";
my $inst = "$root/inst_sge";
-x $inst or die "Cannot execute $inst\n";
$rc = system($inst, qw(-m -x -auto ./SGE_Config));
if ($rc != 0)
    die "$inst failed\n";
print "SGE setup to $root succeeded\n";
__DATA__
# SGE default configuration file
# Use always fully qualified pathnames, please
# SGE_ROOT Path, this is basic information
#(mandatory for qmaster and execd installation)
SGE_ROOT=@ROOT@
# SGE_QMASTER_PORT is used by qmaster for communication
# Please enter the port in this way: 1300
# Please do not this: 1300/tcp
#(mandatory for qmaster installation)
SGE_QMASTER_PORT=@QMASTER_PORT@
# SGE_EXECD_PORT is used by execd for communication
SGE_EXECD_PORT=@EXECD_PORT@
# CELL_NAME, will be a dir in SGE_ROOT, contains the common dir
# Please enter only the name of the cell. No path, please
CELL_NAME="@CELL_NAME@"
# The dir, where qmaster spools this parts, which are not spooled by DB
QMASTER_SPOOL_DIR=$SGE_ROOT/$CELL_NAME/spool/qmaster
# The dir, where the execd spools (active jobs)
# This entry is needed, even if your are going to use
# berkeley db spooling. Only cluster configuration and jobs will
# be spooled in the database. The execution daemon still needs a spool
# directory
EXECD_SPOOL_DIR=$SGE_ROOT/$CELL_NAME/spool
# For monitoring and accounting of jobs, every job will get
# unique GID. So you have to enter a free GID Range, which
# is assigned to each job running on a machine.
# If you want to run 100 Jobs at the same time on one host you
# have to enter a GID-Range like that: 16000-16100
GID_RANGE=@GID_RANGE@
# If SGE is compiled with -spool-dynamic, you have to enter here, which
# spooling method should be used. (classic or berkeleydb)
SPOOLING_METHOD="berkeleydb"
# Name of the Server, where the Spooling DB is running on
# if spooling methode is berkeleydb, it must be "none", when
# using no spooling server and it must containe the servername
# if a server should be used. In case of "classic" spooling,
# can be left out
DB_SPOOLING_SERVER="none"
# The dir, where the DB spools
# If berkeley db spooling is used, it must contain the path to
# the spooling db. Please enter the full path. (eg. /tmp/data/spooldb)
# Remember, this directory must be local on the qmaster host or on the
# Berkeley DB Server host. No NSF mount, please
DB_SPOOLING_DIR=$SGE_ROOT/$CELL_NAME/spool/spooldb
# A List of Host which should become admin hosts
# If you do not enter any host here, you have to add all of your hosts
# by hand, after the installation. The autoinstallation works without
# any entry
ADMIN_HOST_LIST="@ADMIN_HOSTS@"
# A List of Host which should become submit hosts
# any entry
SUBMIT_HOST_LIST="@SUBMIT_HOSTS@"
# A List of Host which should become exec hosts
# any entry
# (mandatory for execution host installation)
EXEC_HOST_LIST="@EXEC_HOSTS@"
# The dir, where the execd spools (local configuration)
# If you want configure your execution daemons to spool in
# a local directory, you have to enter this directory here.
# If you do not want to configure a local execution host spool directory
# please leave this empty
EXECD_SPOOL_DIR_LOCAL="$SGE_ROOT/$CELL_NAME/spool"
# If true, the domainnames will be ignored, during the hostname resolving
# if false, the fully qualified domain name will be used for name resolving
HOSTNAME_RESOLVING="true"
# Shell, which should be used for remote installation (rsh/ssh)
# This is only supported, if your hosts and rshd/sshd is configured,
# not to ask for a password, or promting any message.
SHELL_NAME="ssh"
# Enter your default domain, if you are using /etc/hosts or NIS configuration
DEFAULT_DOMAIN="none"
# If a job stops, fails, finnish, you can send a mail to this adress
ADMIN_MAIL="none"
# If true, the rc scripts (sgemaster, sgeexecd, sgebdb) will be added,
# to start automatically during boottime
ADD_TO_RC="false"
#If this is "true" the file permissions of executables will be set to 755
#and of ordenary file to 644.
SET_FILE_PERMS="true"
# This option is not implemented, yet.
# When a exechost should be uninstalled, the running jobs will be rescheduled
RESCHEDULE_JOBS="wait"
# Enter a one of the three distributed scheduler tuning configuration sets
# (1=normal, 2=high, 3=max)
SCHEDD_CONF="1"
# The name of the shadow host. This host must have read/write permission
# to the qmaster spool directory
# If you want to setup a shadow host, you must enter the servername
# (mandatory for shadowhost installation)
SHADOW_HOST="none"
# Remove this execution hosts in automatic mode
# (mandatory for unistallation of execution hosts)
EXEC_HOST_LIST_RM="localhost"
# This option is used for startup script removing.
# If true, all rc startup scripts will be removed during
# automatic deinstallation. If false, the scripts won't
# be touched.
# (mandatory for unistallation of execution/qmaster hosts)
REMOVE_RC="false"
