[Bio] / FigCommon / make_sandbox.pl Repository:
Log of /FigCommon/make_sandbox.pl
Links to caBIG-05Apr06-00: (view) (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 5 months ago) by olson
Added license words.
Fri Dec 17 17:14:35 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.3: +8 -7 lines
Updates to make_sandbox
Thu Apr 1 12:59:25 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.2: +0 -1 lines
don't need lwp
Wed Mar 24 17:58:32 2004 UTC (16 years, 2 months ago) by olson
Changes since 1.1: +42 -33 lines
More fixes; this works now with the old-style configure. It patches hte
generated FIG_Config files to point to the right place since configure doesn't have
support for changing those at the moment.
Tue Mar 23 13:35:33 2004 UTC (16 years, 2 months ago) by olson
Script for creating sandbox builds (duplicated from an existing seed).
