[Bio] / FigCommon / make_sandbox.pl Repository:
Log of /FigCommon/make_sandbox.pl
Mon Mar 3 20:40:03 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: HEAD, help, lwc, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.7: +48 -5 lines
more cleanup.
Mon Mar 3 20:23:10 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.6: +65 -16 lines
Update make_sandbox to handle environment config-file configration.
Tue Mar 13 16:04:33 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.5: +110 -17 lines
sandbox creation updates
Mon Dec 5 19:10:06 2005 UTC (13 years, 11 months ago) by olson
Added license words.
Fri Dec 17 17:14:35 2004 UTC (14 years, 10 months ago) by olson
Changes since 1.3: +8 -7 lines
Updates to make_sandbox
Thu Apr 1 12:59:25 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.2: +0 -1 lines
don't need lwp
Wed Mar 24 17:58:32 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.1: +42 -33 lines
More fixes; this works now with the old-style configure. It patches hte
generated FIG_Config files to point to the right place since configure doesn't have
support for changing those at the moment.
Tue Mar 23 13:35:33 2004 UTC (15 years, 7 months ago) by olson
Script for creating sandbox builds (duplicated from an existing seed).
