[Bio] / FigCommon / lwc_postprocess.pl Repository:
Log of /FigCommon/lwc_postprocess.pl
Links to merge-trunktag-bodev_news-3: (view) (download) (as text) (annotate)
Wed Jun 29 19:58:22 2005 UTC (15 years ago) by olson
CVS Tags: caBIG-00-00-00, merge-trunktag-bodev_news-3
debug
Wed Jun 29 19:55:31 2005 UTC (15 years ago) by olson
debug
Wed Jun 29 17:58:57 2005 UTC (15 years ago) by olson
Changes since 1.1: +11 -0 lines
Close stdin/stdtuo before starting services.
Wed Jun 29 17:45:23 2005 UTC (15 years ago) by olson
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
