[Bio] / FigCommon / lwc_postprocess.pl Repository:
Log of /FigCommon/lwc_postprocess.pl
Mon Dec 5 19:10:06 2005 UTC (14 years ago) by olson
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, help, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_release_2008_09_29
Added license words.
Wed Jun 29 19:58:22 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: caBIG-00-00-00, merge-trunktag-bodev_news-3
debug
Wed Jun 29 19:55:31 2005 UTC (14 years, 5 months ago) by olson
debug
Wed Jun 29 17:58:57 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.1: +11 -0 lines
Close stdin/stdtuo before starting services.
Wed Jun 29 17:45:23 2005 UTC (14 years, 5 months ago) by olson
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
