[Bio] / FigCommon / envsub.postgres.pl Repository:
Log of /FigCommon/envsub.postgres.pl
Mon Dec 5 19:10:06 2005 UTC (13 years, 11 months ago) by olson
Changes since 1.9: +17 -0 lines
Added license words.
Mon Mar 7 17:23:31 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.8: +7 -0 lines
Add simple config support for Sprout database.
Tue Dec 21 19:06:43 2004 UTC (14 years, 10 months ago) by olson
Don't allow a negative dbbufs value to sneak into the config file.
Mon Nov 1 20:22:16 2004 UTC (15 years ago) by olson
Changes since 1.6: +0 -1 lines
Tune the configuration stuff in preparation for fixing database stuff.
Thu Jun 3 18:25:21 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.5: +5 -0 lines
Bootstrapping fixes for setting PERL5LIB both at the shell and in tool_hdr_py (For
future use for python->perl calling).
Enable setting sandbox location with env FIGCONFIG_SANDBOX=name
Enable setting db user name with env FIGCONFIG_DBUSER=user
Sat Mar 20 17:44:41 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.4: +22 -1 lines
fix for differing postgres/share locations.
Thu Feb 12 17:05:43 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.3: +14 -3 lines
Invoke postgres commands with full pathname in the start- and stop-servers scripts.
Add the -L option to initdb so that non-default-path installs work properly.
Wed Jan 7 17:17:55 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.2: +1 -5 lines
set the initdb locale to C. we hit a problem on the mac laptop where
the default local wasn't found. Need to also set the LANG environment
variable in the config file.
Tue Jan 6 22:32:01 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.1: +91 -3 lines
Add support for computing number of shared buffers based on available
physical and shared memory.
Add overrides to default database name, port, and buffer count.
Fri Dec 19 22:57:48 2003 UTC (15 years, 10 months ago) by olson
new stuff, so it doesn't get lost.
