Log of /FigCommon/envsub.postgres.pl
Parent Directory
Revision
1.10 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Dec 5 19:10:06 2005 UTC (14 years ago) by
olson
Branch:
MAIN
CVS Tags:
HEAD,
caBIG-05Apr06-00,
caBIG-13Feb06-00,
help,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
rast_2008_0924,
rast_rel_2008_04_23,
rast_rel_2008_06_16,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912,
rast_release_2008_09_29
Changes since
1.9: +17 -0 lines
Diff to
previous 1.9
Added license words.
Revision
1.6 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Jun 3 18:25:21 2004 UTC (15 years, 6 months ago) by
olson
Branch:
MAIN
Changes since
1.5: +5 -0 lines
Diff to
previous 1.5
Bootstrapping fixes for setting PERL5LIB both at the shell and in tool_hdr_py (For
future use for python->perl calling).
Enable setting sandbox location with env FIGCONFIG_SANDBOX=name
Enable setting db user name with env FIGCONFIG_DBUSER=user
Revision
1.4 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Feb 12 17:05:43 2004 UTC (15 years, 10 months ago) by
olson
Branch:
MAIN
Changes since
1.3: +14 -3 lines
Diff to
previous 1.3
Invoke postgres commands with full pathname in the start- and stop-servers scripts.
Add the -L option to initdb so that non-default-path installs work properly.
Revision
1.3 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Jan 7 17:17:55 2004 UTC (15 years, 11 months ago) by
olson
Branch:
MAIN
Changes since
1.2: +1 -5 lines
Diff to
previous 1.2
set the initdb locale to C. we hit a problem on the mac laptop where
the default local wasn't found. Need to also set the LANG environment
variable in the config file.
Revision
1.2 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Jan 6 22:32:01 2004 UTC (15 years, 11 months ago) by
olson
Branch:
MAIN
Changes since
1.1: +91 -3 lines
Diff to
previous 1.1
Add support for computing number of shared buffers based on available
physical and shared memory.
Add overrides to default database name, port, and buffer count.
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
