[Bio] / FigCommon / envsub.mysql.pl Repository:
View of /FigCommon/envsub.mysql.pl
Revision 1.3 - (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 6 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, help, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Added license words.
# Public License.
# Mysql configuration.
print "In envsub mysql\n";
# We should be ready to go. Put the config file directives in.
# We use the current account as the db user.
my $dbuser = (getpwuid($>))[0];
my $dbport = 5432;
push(@$Config, ["dbms", "mysql", 1]);
push(@$Config, ["db", "fig", 1]);
push(@$Config, ["dbuser", $dbuser, 1]);
push(@$Config, ["dbpass", "", 1]);
push(@$Config, ["dbport", $dbport, 0]);
push(@$Config, ["sproutDB", "Sprout", 1]);
# Create the start/stop servers script
# Mysql doesn't need anything there.
#open(FH, ">>$start_servers");
#close(FH);
#open(FH, ">>$stop_servers");
#close(FH);
1;
