[Bio] / FigCommon / env.mac.pl Repository:
View of /FigCommon/env.mac.pl
Revision 1.6 - (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 6 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, help, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Added license words.
# Public License.
# MacPython appears to want this for pythonw use.
use FileHandle;
my $osx_dir = "$ENV{HOME}/.MacOSX";
if (! -d $osx_dir)
    mkdir($osx_dir);
my $plist = "$osx_dir/environment.plist";
if (-f $plist)
    # One already exists, try making a backup if there's not one already.
    my $bak = "$plist.bak";
    if (! -f $bak)
	rename($plist, $bak);
$fh = new FileHandle(">$plist");
my $path = $OtherConfig->{pythonpath};
print $fh <<EOF;
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>DISPLAY</key>
<string>:0.0</string>
<key>PYTHONPATH</key>
<string>$path</string>
</dict>
</plist>
EOF
$fh->close();
# The Mac SEED always uses postgres. Load the postgres intiialization
# code.
# First, determine physical memory size and shmmax parameters.
sub get_sysctl
    my($var) = @_;
    my $sysctl = find_in_path("sysctl", "/sbin", "/usr/sbin");
    if (! -x $sysctl)
	return undef;
    my $out = `$sysctl $var`;
    chomp($out);
    my @a = split(/\s+/, $out);
    return $a[1];
$OtherConfig->{memory} = get_sysctl("hw.memsize");
$OtherConfig->{shmmax} = get_sysctl("kern.sysv.shmmax");
$pg_script = "$ENV{FIGCONFIG_RELEASE_DIR}/FigCommon/envsub.postgres.pl";
run_script($pg_script);
