[Bio] / FigCommon / env.linux-rhel.pl Repository:
Log of /FigCommon/env.linux-rhel.pl
Mon Dec 5 19:10:06 2005 UTC (14 years, 5 months ago) by olson
Added license words.
Fri Jan 14 20:22:04 2005 UTC (15 years, 4 months ago) by olson
Add env config files for Fedora core, Gentoo, and Enterprise Linux configs.
