[Bio] / FigCommon / env.linux-postgres.pl Repository:
Log of /FigCommon/env.linux-postgres.pl
Mon Dec 5 19:10:06 2005 UTC (14 years ago) by olson
Added license words.
Tue Dec 21 19:06:54 2004 UTC (14 years, 11 months ago) by olson
Changes since 1.2: +21 -0 lines
Compute total memory properly on Gentoo.
Wed Jan 7 14:17:14 2004 UTC (15 years, 11 months ago) by olson
Changes since 1.1: +31 -0 lines
Add memory/shm determination code for linux.
Fri Dec 19 22:57:48 2003 UTC (15 years, 11 months ago) by olson
new stuff, so it doesn't get lost.
