[Bio] / FigCommon / env.linux-mysql.pl Repository:
Log of /FigCommon/env.linux-mysql.pl
Mon Dec 5 19:10:06 2005 UTC (14 years, 3 months ago) by olson
Added license words.
Tue Jan 6 20:12:51 2004 UTC (16 years, 2 months ago) by olson
Changes since 1.1: +8 -28 lines
Linux mysql changes.
Fri Dec 19 22:57:48 2003 UTC (16 years, 3 months ago) by olson
new stuff, so it doesn't get lost.
