[Bio] / FigCommon / env.linux-gentoo.pl Repository:
View of /FigCommon/env.linux-gentoo.pl
Revision 1.2 - (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, help, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Added license words.
# Public License.
# Linux-postgres-specific configuration.
# Invoke the postgres-specific configuration.
# We'll find it in the FigCommon directory.
#$ cat /proc/meminfo
#        total:    used:    free:  shared: buffers:  cached:
#	Mem:  526127104 519618560  6508544        0 117166080 330891264
#	Swap: 263200768 93118464 170082304
my $fh;
if (open($fh, "</proc/meminfo"))
    while (<$fh>)
	print;
	if (/^Mem:\s+(\d+)/)
	    $OtherConfig->{memory} = $1;
	    last;
	elsif (/^MemTotal:\s+(\d+)\s+(\S+)/)
	    my $mem = $1;
	    my $units = lc($2);
	    if ($units eq "kb")
		$mem *= 1024;
	    elsif ($units eq "mb")
		$mem *= 1024 * 1024;
	    elsif ($units eq "gb")
		$mem *= 1024 * 1024 * 1024;
	    $OtherConfig->{memory} = $mem;
	    last;
    close($fh);
if (open($fh, "</proc/sys/kernel/shmmax"))
    $_ = <$fh>;
    if (/^(\d+)$/)
	$OtherConfig->{shmmax} = $1;
$pg_script = "$ENV{FIGCONFIG_RELEASE_DIR}/FigCommon/envsub.postgres.pl";
run_script($pg_script);
