[Bio] / FigCommon / configure Repository:
Log of /FigCommon/configure
Links to rast_rel_2010_0928: (view) (download) (annotate)
Tue Sep 23 03:49:33 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: HEAD, help, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Tue Sep 23 02:55:16 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.6: +8 -4 lines
Allowed specification of the directory name, to keep the anno out of the configuration.
Wed Jan 2 17:22:09 2008 UTC (12 years, 5 months ago) by olson
CVS Tags: lwc, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.5: +5 -1 lines
do hostname/hosttype matching
Tue Nov 27 23:16:21 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.4: +29 -7 lines
Changes to support more portable installs that work across multiple architectures.
Mon Dec 5 19:10:06 2005 UTC (14 years, 5 months ago) by olson
Added license words.
Mon May 23 14:48:05 2005 UTC (15 years ago) by olson
Changes since 1.2: +26 -0 lines
Mods for finding subdirs of env/lib that shoudl be in LD_LIBRARY_PATH.
Add perl libdir if perl was built with a shared libperl.so.
Mon Nov 1 20:22:16 2004 UTC (15 years, 7 months ago) by olson
Tune the configuration stuff in preparation for fixing database stuff.
Tue Dec 23 16:10:48 2003 UTC (16 years, 5 months ago) by olson
More configure setup.
