[Bio] / FigCommon / configure-env Repository:
Log of /FigCommon/configure-env
Links to caBIG-00-00-00: (view) (download) (annotate)
Wed Dec 17 16:27:11 2003 UTC (16 years, 6 months ago) by efrank
Changes since 1.3: +3 -1 lines
:P2P Stuff
Wed Dec 3 18:14:02 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: delong-01, delong-02
Changes since 1.2: +35 -0 lines
add creation of fig-user-env.csh
Wed Dec 3 01:13:11 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: V00-00-01
Changes since 1.1: +69 -46 lines
configure-env:
  o now writes output files into pwd rather than into various directories.
  o no longer needs to be in fig directory to run
  o Assumes FIG_HOME is set in env rather than assuming it can be
    defined from pwd.  Using the env is bad.  BUt it will do for now
  o Now passes directory to the config-specific scripts so that they
    can find the files to modify.
  o No longer calls make.  We expect to be called *by* make
Mon Dec 1 16:52:59 2003 UTC (16 years, 7 months ago) by efrank
Branch point for: initial
