Log of /FigCommon/bootstrap.pl
Parent Directory
Revision
1.36 -
view)
download)
as text)
annotate)
[selected]
Mon Mar 24 16:04:25 2008 UTC (11 years, 8 months ago) by
olson
Branch:
MAIN
CVS Tags:
HEAD,
help,
lwc,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
rast_2008_0924,
rast_rel_2008_04_23,
rast_rel_2008_06_16,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912,
rast_release_2008_09_29
Changes since
1.35: +4 -1 lines
Diff to
previous 1.35
Add fig-user-env support for HOSTNAME in the env config file.
Revision
1.25 -
view)
download)
as text)
annotate)
[select for diffs]
Tue May 17 17:36:05 2005 UTC (14 years, 6 months ago) by
olson
Branch:
MAIN
Changes since
1.24: +11 -2 lines
Diff to
previous 1.24
to
selected 1.36
Add RTSETENV support.
Add a tiny little SEED-specific tweak to makeScriptHeaders to have it peer in RTROOT/config to see if it has a
RTConfig, and to use that as RTSITELIBDIR if one isn't otherwise set.
Revision
1.11 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Jun 3 18:25:21 2004 UTC (15 years, 6 months ago) by
olson
Branch:
MAIN
Changes since
1.10: +34 -6 lines
Diff to
previous 1.10
to
selected 1.36
Bootstrapping fixes for setting PERL5LIB both at the shell and in tool_hdr_py (For
future use for python->perl calling).
Enable setting sandbox location with env FIGCONFIG_SANDBOX=name
Enable setting db user name with env FIGCONFIG_DBUSER=user
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
