[Bio] / FigCommon / bootstrap.pl Repository:
Log of /FigCommon/bootstrap.pl
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.27: +17 -0 lines
Diff to previous 1.27 , to selected 1.23
Added license words.
Mon May 23 14:49:28 2005 UTC (14 years, 7 months ago) by olson
Diff to previous 1.26 , to selected 1.23
fix typo
Mon May 23 14:48:05 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.25: +54 -1 lines
Diff to previous 1.25 , to selected 1.23
Mods for finding subdirs of env/lib that shoudl be in LD_LIBRARY_PATH.
Add perl libdir if perl was built with a shared libperl.so.
Tue May 17 17:36:05 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.24: +11 -2 lines
Diff to previous 1.24 , to selected 1.23
Add RTSETENV support.
Add a tiny little SEED-specific tweak to makeScriptHeaders to have it peer in RTROOT/config to see if it has a
RTConfig, and to use that as RTSITELIBDIR if one isn't otherwise set.
Fri May 6 22:10:16 2005 UTC (14 years, 8 months ago) by olson
Diff to previous 1.23
reorder path
Revision 1.23 - (view) (download) (as text) (annotate) - [selected]
Fri May 6 22:03:03 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.22: +34 -5 lines
Diff to previous 1.22
Rearrange paths some.
Write an RTConfig.
Wed May 4 21:42:50 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.21: +1 -0 lines
Diff to previous 1.21 , to selected 1.23
Mon Mar 7 17:23:31 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.20: +2 -0 lines
Diff to previous 1.20 , to selected 1.23
Add simple config support for Sprout database.
Tue Jan 25 20:47:00 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.19: +5 -0 lines
Diff to previous 1.19 , to selected 1.23
Add creation of rtpath alias.
Mon Nov 1 20:26:12 2004 UTC (15 years, 2 months ago) by olson
Diff to previous 1.18 , to selected 1.23
Remove code that we don't have yet.
Mon Nov 1 20:22:16 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.17: +3 -0 lines
Diff to previous 1.17 , to selected 1.23
Tune the configuration stuff in preparation for fixing database stuff.
Tue Oct 19 17:49:44 2004 UTC (15 years, 3 months ago) by olson
Diff to previous 1.16 , to selected 1.23
fix a dumb typo
Mon Oct 18 21:51:53 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.15: +9 -0 lines
Diff to previous 1.15 , to selected 1.23
Fix initial boot strap problem (add env/arch/bin to path, set up PERL5LIB properly).
Tue Aug 10 16:24:07 2004 UTC (15 years, 5 months ago) by olson
Diff to previous 1.14 , to selected 1.23
Fix #! problem on mac-jaguar.
Thu Jun 3 21:07:09 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.13: +3 -2 lines
Diff to previous 1.13 , to selected 1.23
add kernelpackages to perl path
Thu Jun 3 19:45:57 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.12: +7 -0 lines
Diff to previous 1.12 , to selected 1.23
use #!/usr/bin/env when using the python out of the compile denvironment.
Thu Jun 3 18:33:20 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.11: +4 -2 lines
Diff to previous 1.11 , to selected 1.23
More tweaks for python->perl calling.
Thu Jun 3 18:25:21 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.10: +34 -6 lines
Diff to previous 1.10 , to selected 1.23
Bootstrapping fixes for setting PERL5LIB both at the shell and in tool_hdr_py (For
future use for python->perl calling).
Enable setting sandbox location with env FIGCONFIG_SANDBOX=name
Enable setting db user name with env FIGCONFIG_DBUSER=user
Thu Apr 1 12:59:40 2004 UTC (15 years, 9 months ago) by olson
Diff to previous 1.9 , to selected 1.23
put fig paths at the front
Fri Mar 19 21:58:31 2004 UTC (15 years, 10 months ago) by golsen
Changes since 1.8: +9 -0 lines
Diff to previous 1.8 , to selected 1.23
Relative base address support and cgi_url() based on current http request
Mon Feb 16 17:14:38 2004 UTC (15 years, 11 months ago) by olson
Diff to previous 1.7 , to selected 1.23
Fixes to add FIG.py support.
Thu Feb 12 17:04:53 2004 UTC (15 years, 11 months ago) by olson
Changes since 1.6: +38 -22 lines
Diff to previous 1.6 , to selected 1.23
Fix python-detection code on mac.
Add invocation of start_services and stop_services to the start- and stop-servers scripts.
Sun Jan 11 20:09:10 2004 UTC (16 years ago) by olson
Diff to previous 1.5 , to selected 1.23
Fix typo.
Tue Jan 6 22:32:38 2004 UTC (16 years ago) by olson
Diff to previous 1.4 , to selected 1.23
add support for searching in extra directories to find_in_path
Tue Dec 23 19:20:44 2003 UTC (16 years ago) by olson
Changes since 1.3: +12 -1 lines
Diff to previous 1.3 , to selected 1.23
new build structure.
Tue Dec 23 17:56:32 2003 UTC (16 years ago) by olson
Changes since 1.2: +2 -5 lines
Diff to previous 1.2 , to selected 1.23
Only set @INC if prefix has changed.
Tue Dec 23 16:10:48 2003 UTC (16 years ago) by olson
Changes since 1.1: +53 -22 lines
Diff to previous 1.1 , to selected 1.23
More configure setup.
Fri Dec 19 22:57:48 2003 UTC (16 years, 1 month ago) by olson
Diff to selected 1.23
new stuff, so it doesn't get lost.
