[Bio] / FigCommon / SwitchRelease.pm Repository:
Log of /FigCommon/SwitchRelease.pm
Fri Nov 30 19:52:42 2007 UTC (12 years, 7 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_release_2008_09_29
Changes since 1.15: +3 -0 lines
add some more dirs to the module list
Mon Dec 5 19:10:06 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.14: +17 -0 lines
Added license words.
Wed Jun 29 20:02:53 2005 UTC (15 years ago) by olson
CVS Tags: caBIG-00-00-00, merge-trunktag-bodev_news-3
Changes since 1.13: +0 -2 lines
Remove debuug
Wed Jun 29 19:46:49 2005 UTC (15 years ago) by olson
Changes since 1.12: +2 -0 lines
catchign up
Wed Jun 29 18:35:35 2005 UTC (15 years ago) by olson
Changes since 1.11: +2 -0 lines
add some debug.
Wed Jun 29 17:45:23 2005 UTC (15 years ago) by olson
Changes since 1.10: +18 -2 lines
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
Tue May 17 17:36:05 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.9: +21 -0 lines
Add RTSETENV support.
Add a tiny little SEED-specific tweak to makeScriptHeaders to have it peer in RTROOT/config to see if it has a
RTConfig, and to use that as RTSITELIBDIR if one isn't otherwise set.
Tue May 17 16:22:03 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.8: +221 -13 lines
RTConfig support.
Mon May 9 22:00:52 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.7: +2 -0 lines
add blastmat to tool_hdr creation.
Mon May 9 15:28:05 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.6: +4 -0 lines
Force FIG/bin and env/<arch>/bin to the front of the path.
Mon Jun 7 15:19:10 2004 UTC (16 years, 1 month ago) by olson
Need to add `import os' to the added python code.
Fri Jun 4 21:53:57 2004 UTC (16 years, 1 month ago) by olson
fixup call to getnev
Thu Jun 3 18:25:21 2004 UTC (16 years, 1 month ago) by olson
Bootstrapping fixes for setting PERL5LIB both at the shell and in tool_hdr_py (For
future use for python->perl calling).
Enable setting sandbox location with env FIGCONFIG_SANDBOX=name
Enable setting db user name with env FIGCONFIG_DBUSER=user
Fri May 21 18:13:17 2004 UTC (16 years, 1 month ago) by olson
create a FIG/Tutorial symlink to the current tutorial code.
Tue Jan 6 22:39:16 2004 UTC (16 years, 6 months ago) by olson
just remove symlinks to CGI and bin
Tue Dec 23 16:19:23 2003 UTC (16 years, 6 months ago) by olson
forgot this one
