[Bio] / FigCommon / Makefile Repository:
Log of /FigCommon/Makefile
Links to rast_rel_2008_04_23: (view) (download) (annotate)
Tue Dec 4 20:09:03 2007 UTC (12 years, 7 months ago) by olson
CVS Tags: HEAD, help, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.15: +2 -1 lines
Rollup of release engineering changes that shoudl  make multi-architecture
installs happier.
Wed Jul 25 20:15:13 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.14: +5 -5 lines
Mon Dec 5 19:10:06 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.13: +17 -0 lines
Added license words.
Wed Jun 29 17:45:23 2005 UTC (15 years ago) by olson
CVS Tags: caBIG-00-00-00, lwc, merge-trunktag-bodev_news-3
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
Mon May 16 18:28:15 2005 UTC (15 years, 2 months ago) by olson
Changes since 1.11: +51 -0 lines
Add the machinery to edit the env's perl Config.pm, but don't enable it. I don't
trust this yet.
Fri Nov 19 22:02:55 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.10: +3 -0 lines
Fix makefiles for change in releasetools.
Mon Nov 1 20:22:16 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.9: +2 -1 lines
Tune the configuration stuff in preparation for fixing database stuff.
Wed Sep 29 18:22:53 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.8: +2 -0 lines
Changes for new toplevel makefile structure.
Tue May 4 16:25:34 2004 UTC (16 years, 2 months ago) by olson
Update ../Makefile if we have a new Makefile.top
Wed Mar 31 17:04:46 2004 UTC (16 years, 3 months ago) by olson
Added build_cgi script.
Moved tool_hdr scripts here.
Tue Mar 23 13:36:03 2004 UTC (16 years, 3 months ago) by olson
Add make_sandbox to bin scripts.
Tue Jan 6 22:39:28 2004 UTC (16 years, 6 months ago) by olson
Changes since 1.4: +5 -7 lines
install SwitchRelase.pm into packages dir
Tue Dec 23 16:10:48 2003 UTC (16 years, 6 months ago) by olson
Changes since 1.3: +5 -5 lines
More configure setup.
Fri Dec 19 17:25:40 2003 UTC (16 years, 6 months ago) by efrank
Switch to release script
Wed Dec 3 02:31:02 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: V00-00-01, delong-01, delong-02
Changes since 1.1: +8 -1 lines
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:45:46 2003 UTC (16 years, 7 months ago) by efrank
add a makefile
