[Bio] / FigCommon / Makefile Repository:
Log of /FigCommon/Makefile
Links to V00-00-01: (view) (download) (annotate)
Wed Dec 3 02:31:02 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: V00-00-01, delong-01, delong-02
Changes since 1.1: +8 -1 lines
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:45:46 2003 UTC (16 years, 7 months ago) by efrank
add a makefile
