[Bio] / FigCommon / Makefile Repository:
Log of /FigCommon/Makefile
Links to caBIG-05Apr06-00: (view) (download) (annotate)
Mon Dec 5 19:10:06 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.13: +17 -0 lines
Diff to previous 1.13 , to selected 1.10
Added license words.
Wed Jun 29 17:45:23 2005 UTC (15 years ago) by olson
CVS Tags: caBIG-00-00-00, lwc, merge-trunktag-bodev_news-3
Diff to previous 1.12 , to selected 1.10
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
Mon May 16 18:28:15 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.11: +51 -0 lines
Diff to previous 1.11 , to selected 1.10
Add the machinery to edit the env's perl Config.pm, but don't enable it. I don't
trust this yet.
Fri Nov 19 22:02:55 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.10: +3 -0 lines
Fix makefiles for change in releasetools.
Revision 1.10 - (view) (download) (annotate) - [selected]
Mon Nov 1 20:22:16 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.9: +2 -1 lines
Tune the configuration stuff in preparation for fixing database stuff.
Wed Sep 29 18:22:53 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.8: +2 -0 lines
Diff to previous 1.8 , to selected 1.10
Changes for new toplevel makefile structure.
Tue May 4 16:25:34 2004 UTC (16 years, 2 months ago) by olson
Diff to previous 1.7 , to selected 1.10
Update ../Makefile if we have a new Makefile.top
Wed Mar 31 17:04:46 2004 UTC (16 years, 3 months ago) by olson
Diff to previous 1.6 , to selected 1.10
Added build_cgi script.
Moved tool_hdr scripts here.
Tue Mar 23 13:36:03 2004 UTC (16 years, 3 months ago) by olson
Diff to previous 1.5 , to selected 1.10
Add make_sandbox to bin scripts.
Tue Jan 6 22:39:28 2004 UTC (16 years, 6 months ago) by olson
Changes since 1.4: +5 -7 lines
Diff to previous 1.4 , to selected 1.10
install SwitchRelase.pm into packages dir
Tue Dec 23 16:10:48 2003 UTC (16 years, 6 months ago) by olson
Changes since 1.3: +5 -5 lines
Diff to previous 1.3 , to selected 1.10
More configure setup.
Fri Dec 19 17:25:40 2003 UTC (16 years, 6 months ago) by efrank
Diff to previous 1.2 , to selected 1.10
Switch to release script
Wed Dec 3 02:31:02 2003 UTC (16 years, 7 months ago) by efrank
CVS Tags: V00-00-01, delong-01, delong-02
Changes since 1.1: +8 -1 lines
Diff to previous 1.1 , to selected 1.10
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:45:46 2003 UTC (16 years, 7 months ago) by efrank
Diff to selected 1.10
add a makefile
