[Bio] / FigCommon / Makefile Repository:
View of /FigCommon/Makefile
Revision 1.13 - (download) (annotate)
Wed Jun 29 17:45:23 2005 UTC (15 years ago) by olson
CVS Tags: lwc, caBIG-00-00-00, merge-trunktag-bodev_news-3
Add lwc_postprocess to restart persistent servers at lightweight code update / swtich_to_release time.
Don't allow a switch_to_release to a symlink.
BINSCRIPTS := configure-env switch_to_release make_sandbox tool_hdr tool_hdr_py \
	setup-sge sge-daemons lwc_postprocess
PERLPACKAGES := $(wildcard *.pm)
lib:	$(foreach var, $(PERLPACKAGES), $(libdir)/$(PKGNAME)/$(var))
bin:	$(foreach var, $(BINSCRIPTS), $(bindir)/$(var))
schematools:
stDeclFiles:
stGeneratedFiles:
# Machinery to fix perl's Config.pm to have the correct paths
# for this installation of the SEED environment - we may be
# running in a directory other than that the perl was compiled for.
PERL = $(RTROOT)/env/$(RTARCH)/bin/perl
# Determine the architecture name and version for the SEED environment perl.
PERL_ARCH = $(shell $(PERL) -e 'use Config; print $$Config{archname}')
PERL_VERS = $(shell $(PERL) -e 'use Config; print $$Config{version}')
# Use these to determine the directory in which Config.pm is located.
PERL_ARCH_LIB = $(RTROOT)/env/$(RTARCH)/lib/perl5/$(PERL_VERS)/$(PERL_ARCH)
PERL_CONFIG_DIST = $(PERL_ARCH_LIB)/Config.pm.dist
PERL_CONFIG = $(PERL_ARCH_LIB)/Config.pm
# The SEED environment has a file PREFIX that declares the location
# to which the environment was installed at compilation time.
PERL_INST_PREFIX = $(shell cat $(RTROOT)/env/$(RTARCH)/PREFIX)
# Fix Config.pm by replacing the install prefix with the current location.
fix_perl_configpm: $(PERL_CONFIG_DIST)
	chmod +w $(PERL_CONFIG)
	sed -e 's,$(PERL_INST_PREFIX),$(RTROOT)/env/$(RTARCH),g' < $(PERL_CONFIG_DIST) > $(PERL_CONFIG)
	chmod -w $(PERL_CONFIG)
	touch fix_perl_configpm
# Copy the original Config.pm to Config.pm.dist if we haven't done so before.
$(PERL_CONFIG_DIST): $(PERL_CONFIG)
	if [ ! -f $(PERL_CONFIG_DIST) ] ; then \
		cp $(PERL_CONFIG) $(PERL_CONFIG_DIST); \
	fi
	chmod -w $(PERL_CONFIG_DIST)
	touch $(PERL_CONFIG_DIST)
	chmod +w $(PERL_CONFIG_DIST)
test:
clean:
	-rm fix_perl_configpm
$(bindir)/%: $(TOPDIR)/$(PKGNAME)/%
	cp -p $< $(bindir)/.
$(bindir)/%: $(TOPDIR)/$(PKGNAME)/%.pl $(TOOL_HDR)
	( cat $(TOOL_HDR) $< > $@; chmod +x $@ )
$(libdir)/$(PKGNAME)/%.pm: $(TOPDIR)/$(PKGNAME)/%.pm
	cp -p  $< $@
