[Bio] / FigCSS / Makefile Repository:
Log of /FigCSS/Makefile
Links to merge-trunktag-bobdev_news-2: (view) (download) (annotate)
Sat Mar 19 22:11:15 2005 UTC (14 years, 7 months ago) by redwards
CVS Tags: Root-bobdev_news, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
changes to organisms.cgi and css to make them work for IE and other browsers
Revision 1.2 - (view) (download) (annotate) - [selected]
Sun Mar 13 01:41:15 2005 UTC (14 years, 7 months ago) by redwards
Changes to stylesheets and code to move tables around. Without using tables.
Sun Mar 13 01:28:31 2005 UTC (14 years, 7 months ago) by efrank
Branch point for: redwards
Diff to selected 1.2
