[Bio] / DrugTargets / peg_pdb_dist.pl Repository:
Log of /DrugTargets/peg_pdb_dist.pl
Fri Sep 2 19:15:45 2005 UTC (14 years, 9 months ago) by hwang
CVS Tags: HEAD
changed to fasta.bound/fasta.free instead of fasta.bound.txt/fasta.free.txt
Thu Aug 25 23:22:54 2005 UTC (14 years, 9 months ago) by fangfang
Fixed the conservation script bug thanks to Bob.
Added category codes instructions page.
Tue Jul 5 17:54:51 2005 UTC (14 years, 10 months ago) by fangfang
Changed two paths to protdist and fasta.free data.
$FIG_Config::ext_bin/protdist
$FIG_Config::fig/var/DrugTargets/fasta.free.txt
Tue Jul 5 16:11:54 2005 UTC (14 years, 10 months ago) by fangfang
