[Bio] / DrugTargets / gen_dt_table.pl Repository:
Log of /DrugTargets/gen_dt_table.pl
Fri Aug 26 16:58:56 2005 UTC (14 years, 3 months ago) by fangfang
CVS Tags: HEAD
Changes since 1.7: +10 -7 lines
Added 'use strict;' and modified codes accordingly.
Tue Aug 23 04:30:13 2005 UTC (14 years, 3 months ago) by fangfang
Fixed a bug in Makefile
Tue Aug 23 03:32:58 2005 UTC (14 years, 3 months ago) by fangfang
Changes since 1.5: +2 -3 lines
Added new algorithm for computing degree of sequence conservation.
The algorithm looks for the homologs of one peg in 10 fixed organisms,
and uses clustalw to align the 10 sequences. Conservation value is then
calculated based on the aligned fasta file.
The algorithm decides which 10 organisms to compare based on whether
this peg belongs to a gram positive bacteria or not.
cons_orgs_list1.txt: Firmicutes
cons_orgs_list2.txt: Proteobacteria
Mon Aug 22 06:58:01 2005 UTC (14 years, 3 months ago) by fangfang
Changes since 1.4: +89 -77 lines
Now support multiple hits for one gene search key.
Thu Aug 18 05:21:41 2005 UTC (14 years, 4 months ago) by fangfang
Changes since 1.3: +7 -4 lines
Changed the directory to save master tables on uchicago machines.
Thu Aug 18 03:35:55 2005 UTC (14 years, 4 months ago) by fangfang
Changes since 1.2: +82 -51 lines
Drug Targets Portal:
  View Existing Tables
  Work on New Tables
Five more columns of CLiBE energy information are added to the table.
Mon Aug 15 17:03:29 2005 UTC (14 years, 4 months ago) by fangfang
Made drug_targets table downloadable as Excel files.
Wed Aug 10 21:24:19 2005 UTC (14 years, 4 months ago) by fangfang
Pipeline for generating a DrugTargets table based on user input gene search keys.
