[Bio] / DrugTargets / drug_targets_table.pl Repository:
Log of /DrugTargets/drug_targets_table.pl
Wed Aug 31 15:31:29 2005 UTC (14 years, 4 months ago) by hwang
CVS Tags: HEAD
Changed files to incorporate fangfang's and kaitlyn's script.
ShowTable.pl
	Shows and edits the tables in the archives
Thu Aug 18 03:35:55 2005 UTC (14 years, 5 months ago) by fangfang
Changes since 1.6: +87 -56 lines
Drug Targets Portal:
  View Existing Tables
  Work on New Tables
Five more columns of CLiBE energy information are added to the table.
Mon Aug 15 18:08:56 2005 UTC (14 years, 5 months ago) by fangfang
Changed downloading file directory.
Mon Aug 15 18:08:09 2005 UTC (14 years, 5 months ago) by fangfang
Changes since 1.4: +14 -3 lines
Modified Excel format to HTML-based Excel.
Mon Aug 15 17:03:29 2005 UTC (14 years, 5 months ago) by fangfang
Changes since 1.3: +3 -3 lines
Made drug_targets table downloadable as Excel files.
Wed Aug 10 23:26:45 2005 UTC (14 years, 5 months ago) by fangfang
Changes since 1.2: +9 -7 lines
Fixed a bug in downloading Excel table.
Wed Aug 10 22:26:14 2005 UTC (14 years, 5 months ago) by fangfang
Changes since 1.1: +17 -9 lines
Added "Export to Excel" functionality on the user-generated table.
Wed Aug 10 21:24:19 2005 UTC (14 years, 5 months ago) by fangfang
Diff to selected 1.3
Pipeline for generating a DrugTargets table based on user input gene search keys.
