[Bio] / DrugTargets / aln_conservation.pl Repository:
Log of /DrugTargets/aln_conservation.pl
Thu Aug 25 23:22:54 2005 UTC (14 years, 9 months ago) by fangfang
CVS Tags: HEAD
Fixed the conservation script bug thanks to Bob.
Added category codes instructions page.
Tue Aug 23 03:32:58 2005 UTC (14 years, 9 months ago) by fangfang
Changes since 1.1: +20 -6 lines
Added new algorithm for computing degree of sequence conservation.
The algorithm looks for the homologs of one peg in 10 fixed organisms,
and uses clustalw to align the 10 sequences. Conservation value is then
calculated based on the aligned fasta file.
The algorithm decides which 10 organisms to compare based on whether
this peg belongs to a gram positive bacteria or not.
cons_orgs_list1.txt: Firmicutes
cons_orgs_list2.txt: Proteobacteria
Wed Aug 10 21:21:35 2005 UTC (14 years, 9 months ago) by fangfang
Calculate the degree of conservation among phylogenetically close sequences.
