[Bio] / DrugTargets / ShowTable.pl Repository:
Log of /DrugTargets/ShowTable.pl
Mon Oct 2 22:01:11 2006 UTC (13 years, 2 months ago) by hwang
CVS Tags: HEAD
Changes since 1.21: +56 -38 lines
Diff to previous 1.21
Take out columns that are not wanted by Leslie
Tue May 16 19:06:36 2006 UTC (13 years, 7 months ago) by hwang
Changes since 1.20: +8 -8 lines
Diff to previous 1.20
Files were changed to separate the links from the text. Links need to be separated because links are out of date after awhile.
The saved text in drug_targets.pl is in a format recognized by ShowTable.pl
Mon Feb 6 14:20:15 2006 UTC (13 years, 10 months ago) by hwang
Diff to previous 1.19
fixed protein data base to protein data bank typo
Mon Feb 6 04:51:52 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.18: +3 -1 lines
Diff to previous 1.18
Added Leslie's comments for the front page.
Sun Feb 5 22:08:52 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.17: +5 -5 lines
Diff to previous 1.17
Search boxes are within two horizontal bars
Sun Feb 5 04:55:47 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.16: +5 -3 lines
Diff to previous 1.16
Literature tag was broken because of formating error. Fixed now
Sat Feb 4 03:10:09 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.15: +92 -32 lines
ShowTable.pl:
-took out underscore, improve download feature, improve layouts, sort by author enabled, link to subsystem
ShowTableKey.pl
-improve column description
drug_targets.pl
-link to current list
Fri Feb 3 21:51:03 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.14: +11 -27 lines
cgi should point to Showtable.cgi not test.cgi
Fri Feb 3 21:23:51 2006 UTC (13 years, 10 months ago) by hwang
Changes since 1.13: +148 -48 lines
Additional functionality of getting specific literature. Cleaned the presentation.
Sun Nov 13 00:04:48 2005 UTC (14 years, 1 month ago) by hwang
Changes since 1.12: +136 -91 lines
Add coloring to the table.
Pastel Blue for good pdb, pastel red for bad pdb.
Linked CLibe Attributes to exisiting pdbs
Tue Sep 27 20:12:03 2005 UTC (14 years, 2 months ago) by hwang
Changes since 1.11: +7 -7 lines
For the 9/18 week demo changes...
ShowTableKey.pl  -- we updated to address Rick's comments (Tag,Category explainations)
cat_coding.pl -- updated to be essential projected
ShowTable.pl -- changed *not a good pdb* to *poor pdb hit*
Wed Sep 14 22:32:02 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.10: +4 -3 lines
fixed pdb matching for search query.
Mon Sep 12 18:15:42 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.9: +16 -4 lines
ShowTable.pl - added thanks and directions
Mon Sep 12 04:13:00 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.8: +30 -6 lines
ShowTable.pl - added a subroutine to delete old temporarily files
best_pdb.pl, drug_targets.pl, ShowTable.pl - The temporarily files were not created in consistant places. Changed all
    temporary files to be created in the Fig_Config::Tmp directory
Sat Sep 10 20:24:03 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.7: +148 -129 lines
ShowTableKey is a key of the categories.
ShowTable - added numerical sort, fixed getPDBs
Tue Sep 6 19:30:45 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.6: +61 -32 lines
ShowTable.pl - changed syntax so that is won't break for "".
             - Added print statements to show user for the website what (s)he is searching for
Tue Sep 6 17:33:53 2005 UTC (14 years, 3 months ago) by jzinner
Changes since 1.5: +17 -17 lines
updated ShowTable.pl to not print the columns mentined before.  And not download print columns when downloaded from ShowTable.pl
Tue Sep 6 16:53:03 2005 UTC (14 years, 3 months ago) by jzinner
Changes since 1.4: +69 -2 lines
In ShowTable.pl -- only PDB's with e Values of less than 1e-20 are shown on screen.  Because e Values for PDB's are calculated in a manner similar to how e Values are calcalculated in the SEED we were confident that 1e-20 will return only well matching PDB's.
Many other items are derived from the PDB values so those items are not shown when the PDB match is bad.
When the PDB Free is higher than 1e-20, Don't show:  PDB Free, e Value Free, PDB Free Title, PASS ASP, PASS Wt of Largest Pocket, PDB Seq Lenght, ProtDist Score
When PDB Bound is higher than 1e-20, Don't show: PDB Bound, e Value Bound, PDB Ligand CLiBE, Total E, Van der Waals, Hydrogen Bond, EI, Solvation Energy
To cat_coding.pl I added three extra categrory types SE-K, SE-P, ES-P.
Fri Sep 2 02:05:06 2005 UTC (14 years, 3 months ago) by hwang
Added a button to allow user to save customized query to the master list. The master list can be view
by ShowTable.cgi
Wed Aug 31 20:30:12 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.2: +19 -22 lines
Changed paths so it is not absolute and check to see if path exists.
Wed Aug 31 17:12:59 2005 UTC (14 years, 3 months ago) by hwang
Changes since 1.1: +26 -31 lines
Add columns to tables that have the latest data for CLiBE
Wed Aug 31 15:31:29 2005 UTC (14 years, 3 months ago) by hwang
Changed files to incorporate fangfang's and kaitlyn's script.
ShowTable.pl
	Shows and edits the tables in the archives
