[Bio] / DrugTargets / DrugTargetsWeb.pl Repository:
Log of /DrugTargets/DrugTargetsWeb.pl
Thu Jun 30 21:37:04 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: HEAD
Changes since 1.2: +13 -3 lines
Fix to use the installed data location, print out error to webpage if not found.
Wed Jun 29 18:22:13 2005 UTC (14 years, 5 months ago) by hwang
Changes since 1.1: +3 -9 lines
Added a new file - DrugTargetsWebDetails
Makefile: added the file
Tue Jun 28 21:02:31 2005 UTC (14 years, 5 months ago) by hwang
kaitlyn
adding files
