[Bio] / DeJonghStuff / parse_model.pl Repository:
Log of /DeJonghStuff/parse_model.pl
Links to bar: (view) (download) (as text) (annotate)
Wed Oct 26 18:48:35 2005 UTC (14 years ago) by dejongh
Branch: foo
CVS Tags: bar
Diff to previous 1.1 , to next main 1.2
Import of scripts to parse and load Palsson models into the SEED.  Also
including models for Staph Aureus and E. Coli (minus gene-reaction associatons).
Branch point for: foo
