[Bio] / DeJonghStuff / map_model_to_kegg.pl Repository:
Log of /DeJonghStuff/map_model_to_kegg.pl
Thu Jan 12 19:53:18 2006 UTC (13 years, 10 months ago) by dejongh
CVS Tags: HEAD
Changes since 1.2: +32 -32 lines
updated
Wed Nov 16 22:01:06 2005 UTC (14 years ago) by dejongh
Changes since 1.1: +251 -196 lines
Matching more reactions based on compounds; searching org-specific data in KEGG
Fri Nov 4 16:22:36 2005 UTC (14 years, 1 month ago) by dejongh
Files for mapping models to KEGG reactions
