[Bio] / DeJonghStuff / load_models.pl Repository:
Log of /DeJonghStuff/load_models.pl
Default branch: foo
Wed Oct 26 18:48:35 2005 UTC (14 years, 4 months ago) by dejongh
Branch: MAIN, foo
CVS Tags: HEAD, bar
Import of scripts to parse and load Palsson models into the SEED.  Also
including models for Staph Aureus and E. Coli (minus gene-reaction associatons).
Branch point for: MAIN, foo
