[Bio] / DeJonghStuff / load_models.pl Repository:
View of /DeJonghStuff/load_models.pl
Revision 1.1.1.1 - (download) (as text) (annotate) (vendor branch)
Wed Oct 26 18:48:35 2005 UTC (14 years, 3 months ago) by dejongh
Branch: foo, MAIN
CVS Tags: bar, HEAD
Import of scripts to parse and load Palsson models into the SEED.  Also
including models for Staph Aureus and E. Coli (minus gene-reaction associatons).
# -*- perl -*-
# loads models produced by parse_model.pl into table files that can be loaded into the database
use strict;
use FIG;
my $fig = new FIG;
my %compound_names;
my @compound_name_files = `find $FIG_Config::global/Models -name "compound_name" -print`;
foreach my $file (@compound_name_files)
    open(TMPIN, $file) or die("Couldn't open $file\n");
    print "Opened $file\n";
    while(<TMPIN>)
	my ($cabbrev, $num, $cname) = split "\t", $_;
	chomp $cname;
	if (! exists($compound_names{$cabbrev}))
	    $compound_names{$cabbrev} = $cname;
	elsif ($compound_names{$cabbrev} ne $cname)
	    print "Warning, multiple names for $cabbrev:\n\t$compound_names{$cabbrev}\n\t$cname\n";
    close(TMPIN);
open(CNAMES, ">$FIG_Config::temp/compound_name.table");
open(CIDS, ">$FIG_Config::temp/compound.table");
foreach my $cabbrev (keys %compound_names)
    print CIDS "$cabbrev\n";
    print CNAMES "$cabbrev\t1\t$compound_names{$cabbrev}\n";
close(CNAMES);
close(CIDS);
my %reaction_roles;
my @reaction_role_files = `find $FIG_Config::global/Models -name "reaction_to_role" -print`;
foreach my $file (@reaction_role_files)
    while(<TMPIN>)
	my ($abbrev, $name) = split "\t", $_;
	chomp $name;
	if (! exists($reaction_roles{$abbrev}))
	    $reaction_roles{$abbrev} = $name;
	elsif ($reaction_roles{$abbrev} ne $name)
	    print "Warning, multiple names for $abbrev:\n\t$reaction_roles{$abbrev}\n\t$name\n";
    close(TMPIN);
open(ROLES, ">$FIG_Config::temp/reaction_to_role.table");
foreach my $abbrev (keys %reaction_roles)
    print ROLES "$abbrev\t$reaction_roles{$abbrev}\n";
close(ROLES);
my %reactions;
my @reaction_files = `find $FIG_Config::global/Models -name "reaction" -print`;
foreach my $file (@reaction_files)
    while(<TMPIN>)
	my ($abbrev, $rev) = split "\t", $_;
	chomp $rev;
	if (! exists($reactions{$abbrev}))
	    $reactions{$abbrev} = $rev;
	elsif ($reactions{$abbrev} ne $rev)
	    print "Warning, multiple reversabilities for $abbrev:\n\t$reactions{$abbrev}\n\t$rev\n";
    close(TMPIN);
open(REAC, ">$FIG_Config::temp/reaction.table");
foreach my $abbrev (keys %reactions)
    print REAC "$abbrev\t$reactions{$abbrev}\n";
close(REAC);
my %reaction_compounds;
my @reaction_files = `find $FIG_Config::global/Models -name "reaction_to_compound" -print`;
    my %new_reactions; # keep track of which reactions are first encountered in the current file
    while(my $reaction_compound = <TMPIN>)
	chomp $reaction_compound;
	$reaction_compound =~ /([^\t]+)\t(.+)/;
	my ($abbrev, $cinfo) = ($1, $2);
	if (! exists($reaction_compounds{$abbrev}) || exists($new_reactions{$abbrev}))
	    # load the new reaction
	    $reaction_compounds{$abbrev}{$cinfo} = 1;
	    $new_reactions{$abbrev} = 1;
	elsif (! exists $reaction_compounds{$abbrev}{$cinfo})
	    # current version of reaction has more compouds than version already loaded
	    print "Warning, new compound found for reaction $abbrev: $cinfo\n";
    close(TMPIN);
# redo this in reverse to check for extra compounds in reactions that weren't caught by the first loop
undef %reaction_compounds;
foreach my $file (reverse @reaction_files)
    close(TMPIN);
open(R2C, ">$FIG_Config::temp/reaction_to_compound.table");
foreach my $abbrev (keys %reaction_compounds)
    my $inner = %reaction_compounds->{$abbrev};
    foreach my $cinfo (keys %$inner)
	print R2C "$abbrev\t$cinfo\n";
close(R2C);
# no need to process the gene_to_role or gene_to_reaction or gene_to_peg files any further,
# since genes are unique to each organism
my @gene_to_role_files = `find $FIG_Config::global/Models -name "gene_to_role" -print`;
my @gene_to_reaction_files = `find $FIG_Config::global/Models -name "gene_to_reaction" -print`;
my @gene_to_peg_files = `find $FIG_Config::global/Models -name "gene_to_peg" -print`;
