[Bio] / Clearinghouse / utils.pm Repository:
Log of /Clearinghouse/utils.pm
Fri Mar 27 17:41:35 2015 UTC (4 years, 7 months ago) by olson
CVS Tags: HEAD
Changes since 1.9: +44 -30 lines
Diff to previous 1.9 , to selected 1.6
Lingering fixes.
Thu Apr 5 17:15:58 2007 UTC (12 years, 7 months ago) by olson
CVS Tags: myrast_33
Changes since 1.8: +27 -0 lines
changes for batch registration
Wed Jan 11 22:52:40 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.7: +41 -0 lines
move id allocation stuff here
Wed Jan 11 21:19:21 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.6: +16 -0 lines
Collected clearinghouse updates.
Tue May 10 16:33:03 2005 UTC (14 years, 6 months ago) by disz
Changes since 1.5: +58 -0 lines
Added Duplicate recod checking to subsystems and genome uploads
Thu May 5 16:58:31 2005 UTC (14 years, 6 months ago) by disz
Changes since 1.4: +29 -0 lines
More cleanup to services
Thu May 5 14:07:11 2005 UTC (14 years, 6 months ago) by disz
Changes since 1.3: +46 -0 lines
Clean up services
Tue May 3 20:18:57 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.2: +62 -0 lines
Add validation on subsystems.
Move validation code into utils::validate_package($package_file, $package_type).
Tue May 3 17:38:19 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.1: +14 -2 lines
Add page header.
Mon May 2 21:31:43 2005 UTC (14 years, 6 months ago) by olson
Diff to selected 1.6
Factor some stuff out to utils.pm
Misc cleanup.
add 1-SUBSYSTEM type.
