[Bio] / Clearinghouse / Makefile Repository:
Log of /Clearinghouse/Makefile
Mon Oct 9 16:43:48 2006 UTC (13 years ago) by olson
CVS Tags: HEAD, myrast_33
some minor fixes.
Wed Jan 11 21:19:21 2006 UTC (13 years, 9 months ago) by olson
Collected clearinghouse updates.
Tue Jun 14 16:01:34 2005 UTC (14 years, 4 months ago) by olson
Tue May 3 17:38:18 2005 UTC (14 years, 5 months ago) by olson
Add page header.
Tue May 3 17:37:41 2005 UTC (14 years, 5 months ago) by olson
Remove ref to export script.
Mon May 2 21:31:43 2005 UTC (14 years, 5 months ago) by olson
Factor some stuff out to utils.pm
Misc cleanup.
add 1-SUBSYSTEM type.
Fri Apr 29 19:55:56 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.8: +7 -1 lines
Added genome type description.
Thu Apr 28 18:16:53 2005 UTC (14 years, 5 months ago) by disz
CH CHANGES
Wed Apr 27 17:46:10 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.6: +2 -2 lines
Pull the db stuff out into Clearinghouse::ch_database. This module exports db_init(). It also initializes the
contents of CH_Config to have the database stuff from FIG_Config if it's not already set. This gives us
a good default behavior while allowing modification. For instance, on my laptop which has a mysql
database for the normal SEED, the CH_Config looks like this:
package CH_Config;
$dbms = "Pg";
$db = "clearinghouse";
$dbuser = "olson";
$dbpass = "";
$dbport = "10101";
$service_url = "http://localhost/FIG/clearinghouse_services.cgi";
$dir = "/Users/olson/chdir";
Do some misc cleanup on the services.
Add gen_seed_tables, which generates a postgres input file (suitable for loading with
'psql -f load_seed.sql') for the genomes in the current seed.
Mon Apr 18 16:10:46 2005 UTC (14 years, 6 months ago) by disz
Thu Apr 14 20:46:35 2005 UTC (14 years, 6 months ago) by disz
Added web page for package uploading
Wed Apr 13 21:17:28 2005 UTC (14 years, 6 months ago) by disz
Added upload capability
Wed Apr 13 19:08:46 2005 UTC (14 years, 6 months ago) by disz
Added vanilla browser capability
Thu Apr 7 17:31:34 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.1: +10 -9 lines
Move over to new DBrtns stuff.
Thu Apr 7 15:55:31 2005 UTC (14 years, 6 months ago) by olson
Branch point for: init
