[Bio] / CatalogServices / CatalogEntry.py Repository:
Log of /CatalogServices/CatalogEntry.py
Fri Mar 11 21:33:12 2005 UTC (15 years, 2 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
Changes since 1.13: +13 -14 lines
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Wed Jul 14 20:52:39 2004 UTC (15 years, 10 months ago) by efrank
CVS Tags: V00-00-01, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.12: +2 -3 lines
remove print
Wed Jul 14 20:22:13 2004 UTC (15 years, 10 months ago) by efrank
CVS Tags: forRick-14Jul04-0
Changes since 1.11: +9 -4 lines
getting it to work.  in a rush for rick demo.
Fri Jul 2 22:16:11 2004 UTC (15 years, 11 months ago) by efrank
Changes since 1.10: +3 -3 lines
CatalogEntry:
	fix RecoElem ctor
DBConnect:
	remove print
RecoElem:
	add apply() method to apply func recurseively
MainMenuBar:
	resolv conflict that wa trivial space
Wed Jun 23 19:19:09 2004 UTC (15 years, 11 months ago) by efrank
CVS Tags: larrys-08jul04
migrate import statements to follow move of Recoelem, Reaction, Reactant
from FaST to KahOM
Mon Jun 14 20:45:15 2004 UTC (15 years, 11 months ago) by hwang
CVS Tags: V00-00-00, forKubal-15Jun04
Changes since 1.8: +24 -7 lines
	Added type and rtype for epydoc
Wed Jun 9 22:36:10 2004 UTC (16 years ago) by efrank
Changes since 1.7: +39 -9 lines
o clean up double foundryId problem in FoundryItems
o change names in CatalogEntry to read() and write()
o write the write() method just mentioned
o get writing to work again, propagate changes into PyGUI
o add plugin capability to modelEditor
Wed May 26 01:38:25 2004 UTC (16 years ago) by efrank
Changes since 1.6: +31 -29 lines
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
Thu Apr 15 18:33:53 2004 UTC (16 years, 1 month ago) by park
Changes since 1.5: +12 -3 lines
add fullpath to schema.
start to add it to the python.
Thu Apr 15 14:49:16 2004 UTC (16 years, 1 month ago) by efrank
Changes since 1.4: +4 -4 lines
Add setFoundryItem capability to CatalogEntry, implemented in CatalogEntryBss.
Modifications to CreateCatalog to support this, and to support change
in FoundryId so that the basic id is a string, not an int.
Fri Apr 9 14:49:10 2004 UTC (16 years, 2 months ago) by efrank
Changes since 1.3: +36 -9 lines
mkItem and mkDir to be able to build up the catalog hierarchy.
Fri Mar 26 17:12:46 2004 UTC (16 years, 2 months ago) by efrank
Modifications to install the new Catalog code, FoundryId stuff.  I ripped
out old code as well:  the list of foundryComboBoxes is gone since we now
have just one combo box.
the notion of FoundryId's intVal is gone.  at least for the moment.  it's too hard
at the mment to have a (bottleneck!) central authority to manage the intVals.
so, starting now, foundryId's are based on strings that are notionally URLs and
its up to the dataFoundry manager to make sure all distinct instances at his
site have distinct urls.
this also means that if a foundry moves, then the history information that
refers to it becomes incorrect.
Thu Mar 25 01:01:04 2004 UTC (16 years, 2 months ago) by efrank
Changes since 1.1: +73 -25 lines
Migrating to new Catalog, CatalogEntry, FoundryId design.
ONly part-wayt done.
safety sync.
Fri Feb 6 21:17:58 2004 UTC (16 years, 4 months ago) by efrank
Branch: vendor
CVS Tags: init
Diff to previous 1.1 , to next main 1.14
initial version of package
Branch point for: vendor
