[Bio] / BioSimScratch / loadBuchnera.py Repository:
Log of /BioSimScratch/loadBuchnera.py
Fri Apr 9 14:48:10 2004 UTC (15 years, 6 months ago) by efrank
CVS Tags: HEAD, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Modified files:
	adjustments in data sizes and little details
	destroyBss can probably be simplified.
Added files:
	ReloadBssData loads data into an empty database.  It calls
	the other guys to do the work:  Aiba*, glyc*, loadbuchnera*, testCas*
	buildNewBssCatalog.py:  copies data from old style catalog to new.
1. destroyBss                   deletes EVERYTHING
2. sqlplus
        @Rebuild                rebuilds schema.  reloads some reactions etc.
3. ReloadBssData                puts some data back in...OLD style catalog
4. buildNewBssCatalog.py        copies data from old style catalog to new.
