[Bio] / BioSimScratch / LoadEColiProcStruct.sql Repository:
Log of /BioSimScratch/LoadEColiProcStruct.sql
Default branch: local
Fri Dec 20 20:16:23 2002 UTC (16 years, 9 months ago) by efrank
Branch: MAIN, local
CVS Tags: HEAD, baseline, forRick-14Jul04-0, forRick-14Jul04-1, ldrd-2003-01, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Import baseline version
Branch point for: MAIN, local
