[Bio] / BioSimScratch / InitializeDb.py Repository:
Log of /BioSimScratch/InitializeDb.py
Tue Jul 13 21:49:35 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: HEAD, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
InitDb:
	o make sure top node pathname starts with /
BssFactory:
	o comment out pathHack
Mon Jul 12 20:39:11 2004 UTC (15 years, 4 months ago) by efrank
sets fid info and top catalog node name in database
