[Bio] / BioSimScratch / FnlChartTab.sql Repository:
Log of /BioSimScratch/FnlChartTab.sql
Fri May 9 17:52:54 2003 UTC (16 years, 6 months ago) by efrank
CVS Tags: HEAD, forRick-14Jul04-0, forRick-14Jul04-1, ldrd-2003-01, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.1: +8 -3 lines
loadBss.py
   two classes, bss and Reaction_py.
   bss() represents the biosimscratch schema and has methods to load
	data into it.  the methods are guesses at basic operations
	on the database for building models and will stand behind
	a gui at some point.
   Reaction_py: a class that holds info for a reacction.  its got this
	name to distinguish it from RecoReadout/Reaction.hh.  they
        should probably be meged but that takes a language mix.  this
	one knows how to parse a simple ascii rep of a reaction
Fri Dec 20 20:16:23 2002 UTC (16 years, 10 months ago) by efrank
Branch: local
CVS Tags: baseline
Diff to previous 1.1 , to next main 1.2
Import baseline version
Branch point for: local
