[Bio] / BioSimScratch / CreateCatalog.sql Repository:
Log of /BioSimScratch/CreateCatalog.sql
Mon Jul 12 20:38:19 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: HEAD, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.12: +2 -1 lines
KahOM/KahDataMgr:
	first pass at top level data manager to be returned from catalogentry read
Schema:
	added KahDatabaseInfo to put fid into database.
	create- changed so that no long initialize name of top catalogEntry (see below)
	destroyBss- changed !#/usr/bin/py to env py
FaST:
	txMgr - fixed close()...added self
	BssFactory - now gets fid via kahDatabaseInfo in database
PyGUI
	change so that something or another
Wed May 26 01:38:25 2004 UTC (15 years, 5 months ago) by efrank
Lots of work aimed at getting catalog services to work, incorporating
catalog editing into the model editor, and simplifying the api
for going form path to model in hand to work with.
CatalogEntryTop was changed to CatalogEntrBase and made base of CatalogEntry
rather than other way around to break a dependency loop that was causing
python import problems.  CatalogEntry is still the base class to use
for extending to new data factories.
changed open() to return catalogEntry rather than foundryItemKey.  simpler
for the user and more opportunity to encapsulate.
made catalogEntry able to read a recoElem and return it.  all done in
terms of arch abstractions.  this is temorary.  we will add a Navigator
or Manager class and that will be returned from the CatalogEntry rather
than recoElem.  that's becausee Recoelem is just one of many things
that will be present, e.g., conditions data.
PyGui/MainMenuBar.  split out to help stay sane for when that becomes
more complex.
Moved add seed server to menu bar so that right click in catalog panel
coudl be used to pull up catalog editing tools.
Wed May 5 18:21:52 2004 UTC (15 years, 5 months ago) by park
     Fill out  the routine,  open(path, version),  into the Catalog class.
Thu Apr 15 18:33:53 2004 UTC (15 years, 6 months ago) by park
Changes since 1.9: +2 -1 lines
add fullpath to schema.
start to add it to the python.
Thu Apr 15 14:49:16 2004 UTC (15 years, 6 months ago) by efrank
Add setFoundryItem capability to CatalogEntry, implemented in CatalogEntryBss.
Modifications to CreateCatalog to support this, and to support change
in FoundryId so that the basic id is a string, not an int.
Fri Apr 9 14:48:10 2004 UTC (15 years, 6 months ago) by efrank
Changes since 1.7: +4 -4 lines
Modified files:
	adjustments in data sizes and little details
	destroyBss can probably be simplified.
Added files:
	ReloadBssData loads data into an empty database.  It calls
	the other guys to do the work:  Aiba*, glyc*, loadbuchnera*, testCas*
	buildNewBssCatalog.py:  copies data from old style catalog to new.
1. destroyBss                   deletes EVERYTHING
2. sqlplus
        @Rebuild                rebuilds schema.  reloads some reactions etc.
3. ReloadBssData                puts some data back in...OLD style catalog
4. buildNewBssCatalog.py        copies data from old style catalog to new.
Thu Apr 1 00:04:43 2004 UTC (15 years, 6 months ago) by efrank
destroyBss:
	bliztes all tables, triggers and contraints.
Thu Mar 25 16:27:21 2004 UTC (15 years, 7 months ago) by park
        Add a field, NextVer into the KahCatDirEntry table.
Fri Mar 19 22:22:06 2004 UTC (15 years, 7 months ago) by park
Fri Mar 19 22:18:35 2004 UTC (15 years, 7 months ago) by park
Changes since 1.3: +25 -10 lines
       Add KahFoundryRegistry entity.
       Replace ProcId with (FoundryIF, KeyIntVal, KeyStrVal)
Fri Mar 5 21:27:53 2004 UTC (15 years, 7 months ago) by park
Changes since 1.2: +21 -21 lines
     Add a Kah in the table name.
     Change table names for entry to the Object Model
                 and Provenance.
Fri Feb 13 20:46:48 2004 UTC (15 years, 8 months ago) by park
TriggerCatalog.sql:
	installs triggers in the Catalog domain
CreateCatalog.sql:
	create a special row to locate the root of the catalog
Fri Jan 30 21:20:39 2004 UTC (15 years, 8 months ago) by park
CreateCatalog.sql:
	creates, or recreates, tables related to the catalog
	domain
LoadCatalog.sql:
	just debugging right now.  puts some stuff in there
