[Bio] / BioSimScratch / BssSchema.sql Repository:
Log of /BioSimScratch/BssSchema.sql
Mon Jul 12 20:38:19 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: HEAD, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.4: +16 -0 lines
KahOM/KahDataMgr:
	first pass at top level data manager to be returned from catalogentry read
Schema:
	added KahDatabaseInfo to put fid into database.
	create- changed so that no long initialize name of top catalogEntry (see below)
	destroyBss- changed !#/usr/bin/py to env py
FaST:
	txMgr - fixed close()...added self
	BssFactory - now gets fid via kahDatabaseInfo in database
PyGUI
	change so that something or another
Fri Apr 9 14:48:10 2004 UTC (15 years, 6 months ago) by efrank
Modified files:
	adjustments in data sizes and little details
	destroyBss can probably be simplified.
Added files:
	ReloadBssData loads data into an empty database.  It calls
	the other guys to do the work:  Aiba*, glyc*, loadbuchnera*, testCas*
	buildNewBssCatalog.py:  copies data from old style catalog to new.
1. destroyBss                   deletes EVERYTHING
2. sqlplus
        @Rebuild                rebuilds schema.  reloads some reactions etc.
3. ReloadBssData                puts some data back in...OLD style catalog
4. buildNewBssCatalog.py        copies data from old style catalog to new.
Thu Apr 1 00:04:43 2004 UTC (15 years, 6 months ago) by efrank
destroyBss:
	bliztes all tables, triggers and contraints.
Tue Aug 12 19:30:25 2003 UTC (16 years, 2 months ago) by park
Changes since 1.1: +7 -0 lines
Add sequence for compound ID
Fri May 9 17:52:54 2003 UTC (16 years, 5 months ago) by efrank
CVS Tags: ldrd-2003-01
loadBss.py
   two classes, bss and Reaction_py.
   bss() represents the biosimscratch schema and has methods to load
	data into it.  the methods are guesses at basic operations
	on the database for building models and will stand behind
	a gui at some point.
   Reaction_py: a class that holds info for a reacction.  its got this
	name to distinguish it from RecoReadout/Reaction.hh.  they
        should probably be meged but that takes a language mix.  this
	one knows how to parse a simple ascii rep of a reaction
