[Bio] / Babel / bin / source2ach.py Repository:
Log of /Babel/bin/source2ach.py
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Wed Jul 20 16:41:16 2011 UTC (8 years, 11 months ago) by tharriso
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.11: +31 -6 lines
fig_config independent, db server independent, more options
Mon May 2 21:40:07 2011 UTC (9 years, 2 months ago) by tharriso
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.10: +5 -3 lines
fixed kegg ids
Tue Mar 1 15:21:48 2011 UTC (9 years, 4 months ago) by tharriso
CVS Tags: mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4
Changes since 1.9: +171 -60 lines
added ncbi nr parser, fixed some ontology bugs, parallized parsing of multiple files
Wed Dec 1 15:45:57 2010 UTC (9 years, 7 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011
Changes since 1.8: +29 -11 lines
added parsing and outputting options for getting taxonomy string from genbank files
Fri Nov 12 19:42:55 2010 UTC (9 years, 7 months ago) by tharriso
Changes since 1.7: +7 -3 lines
made obtaining contig data optional
Fri Oct 22 15:12:00 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.6: +4 -4 lines
Tue Oct 19 21:55:53 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.5: +29 -18 lines
Mon Oct 18 15:49:56 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.4: +54 -24 lines
Fri Oct 15 15:34:03 2010 UTC (9 years, 8 months ago) by tharriso
Thu Oct 7 19:27:00 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.2: +10 -0 lines
Wed Sep 22 15:04:24 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.1: +49 -21 lines
added eggnog parsing
Thu Sep 16 21:31:24 2010 UTC (9 years, 9 months ago) by tharriso
