[Bio] / Babel / bin / load_source_data.pl Repository:
Log of /Babel/bin/load_source_data.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Wed Jul 20 16:41:16 2011 UTC (8 years, 10 months ago) by tharriso
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
Changes since 1.10: +26 -7 lines
fig_config independent, db server independent, more options
Thu Apr 28 22:04:01 2011 UTC (9 years, 1 month ago) by tharriso
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.9: +2 -1 lines
modified
Wed Nov 10 22:37:01 2010 UTC (9 years, 6 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4
Changes since 1.8: +5 -1 lines
updated for new source data
Wed Nov 10 18:46:03 2010 UTC (9 years, 6 months ago) by tharriso
Changes since 1.7: +24 -14 lines
changed source download format
Tue Nov 9 22:45:40 2010 UTC (9 years, 6 months ago) by tharriso
Changes since 1.6: +25 -12 lines
added new source data
Mon Nov 8 17:04:37 2010 UTC (9 years, 6 months ago) by tharriso
added source description
Fri Oct 22 02:15:45 2010 UTC (9 years, 7 months ago) by tharriso
Changes since 1.4: +5 -3 lines
Tue Oct 19 21:56:17 2010 UTC (9 years, 7 months ago) by tharriso
Changes since 1.3: +10 -13 lines
Tue Oct 12 16:06:44 2010 UTC (9 years, 7 months ago) by tharriso
Thu Jul 22 15:28:31 2010 UTC (9 years, 10 months ago) by tharriso
ach_data column 'ID' is now lower-case
Wed Jul 21 18:51:16 2010 UTC (9 years, 10 months ago) by tharriso
script to load source metadata from sources.xml into ACH_SOURCES table
