[Bio] / Babel / bin / load_md5rna2db.pl Repository:
Log of /Babel/bin/load_md5rna2db.pl
Wed Jul 20 16:41:16 2011 UTC (8 years, 11 months ago) by tharriso
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
Changes since 1.4: +6 -8 lines
fig_config independent, db server independent, more options
Fri Jul 8 19:39:49 2011 UTC (9 years ago) by tharriso
Changes since 1.3: +3 -3 lines
Fri Mar 25 18:50:31 2011 UTC (9 years, 3 months ago) by tharriso
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0
Changes since 1.2: +13 -14 lines
update for ranked rna taxonomy
Thu Mar 24 21:05:43 2011 UTC (9 years, 3 months ago) by tharriso
added filter to only add to DB where rna has good taxonomic annotation
Wed Dec 1 15:43:35 2010 UTC (9 years, 7 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
initial version
