[Bio] / Babel / bin / load_md5protein2db.pl Repository:
Log of /Babel/bin/load_md5protein2db.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Wed Jul 20 16:41:16 2011 UTC (8 years, 10 months ago) by tharriso
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
Changes since 1.8: +8 -10 lines
fig_config independent, db server independent, more options
Fri Jul 8 19:39:49 2011 UTC (8 years, 10 months ago) by tharriso
Changes since 1.7: +4 -4 lines
Tue Mar 1 15:22:45 2011 UTC (9 years, 2 months ago) by tharriso
CVS Tags: mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0
modifications and bug fixes
Wed Feb 23 16:52:04 2011 UTC (9 years, 3 months ago) by tharriso
added option for sort temp dir
Mon Feb 21 22:32:21 2011 UTC (9 years, 3 months ago) by tharriso
fixed typo with alias table column name
Wed Dec 1 15:44:10 2010 UTC (9 years, 5 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011
Changes since 1.3: +8 -2 lines
clean up, minor bug fixes
Fri Oct 22 15:12:00 2010 UTC (9 years, 7 months ago) by tharriso
Changes since 1.2: +138 -105 lines
Tue Oct 19 21:55:53 2010 UTC (9 years, 7 months ago) by tharriso
Changes since 1.1: +85 -61 lines
Mon Oct 18 15:50:49 2010 UTC (9 years, 7 months ago) by tharriso
