[Bio] / Babel / bin / load_MD5DATA2DB.pl Repository:
Log of /Babel/bin/load_MD5DATA2DB.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Thu Oct 7 19:27:00 2010 UTC (9 years, 7 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2
Changes since 1.5: +148 -66 lines
Tue Aug 31 19:30:11 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.4: +5 -4 lines
Mon Aug 30 18:28:14 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.3: +3 -4 lines
Fri Aug 27 19:46:04 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.2: +34 -22 lines
fixed multi-file input, changed field name
Thu Jul 22 15:34:00 2010 UTC (9 years, 10 months ago) by tharriso
Changes since 1.1: +121 -159 lines
1. modified to work with postgresql DB
2. some tricks used to speed up inserts (autocommit turned off, indexes removed, retrieve seriel id during insert)
3. can load multiple files at once
Thu Jul 15 20:29:17 2010 UTC (9 years, 10 months ago) by wilke
