[Bio] / Babel / bin / create_pg_tables.sql Repository:
Log of /Babel/bin/create_pg_tables.sql
Links to mgrast_dev_08112011: (view) (download) (annotate)
Fri May 6 20:53:27 2011 UTC (9 years, 2 months ago) by tharriso
CVS Tags: HEAD, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
Changes since 1.16: +14 -0 lines
Diff to previous 1.16
added md5_lca table
Fri Mar 25 18:50:31 2011 UTC (9 years, 3 months ago) by tharriso
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4
Changes since 1.15: +1 -0 lines
update for ranked rna taxonomy
Thu Feb 24 16:59:05 2011 UTC (9 years, 4 months ago) by tharriso
CVS Tags: mgrast_dev_03052011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.14: +1 -0 lines
added column 'uniq_md5s' to sources table
Wed Nov 10 22:37:01 2010 UTC (9 years, 8 months ago) by tharriso
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011
Changes since 1.13: +1 -0 lines
updated for new source data
Wed Nov 10 18:46:03 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.12: +2 -2 lines
changed source download format
Tue Nov 9 22:45:40 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.11: +3 -1 lines
added new source data
Tue Nov 9 20:16:17 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.10: +2 -0 lines
added version and last_update columns to sources table
Mon Nov 8 17:04:15 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.9: +1 -0 lines
Wed Nov 3 20:29:47 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.8: +1 -0 lines
Sat Oct 23 02:48:27 2010 UTC (9 years, 8 months ago) by tharriso
Fri Oct 22 02:15:42 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.6: +30 -18 lines
Tue Oct 19 21:55:53 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.5: +24 -27 lines
Mon Oct 18 15:49:56 2010 UTC (9 years, 8 months ago) by tharriso
Changes since 1.4: +80 -60 lines
Mon Oct 4 03:53:07 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.3: +2 -4 lines
Mon Sep 27 16:43:28 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.2: +12 -1 lines
Wed Sep 22 15:02:58 2010 UTC (9 years, 9 months ago) by tharriso
Changes since 1.1: +12 -23 lines
Thu Sep 16 21:22:43 2010 UTC (9 years, 9 months ago) by tharriso
new versions
